If the code could retain points values across mutiple runs, could it ( the code ) then be asked to scan say  2 and a half D object ( no cavity searches ) and store the profile information for later recreation of the object.
This ofcourse implies a different kind of probe construction, one which relies on internal to the probe contacts.
						Scanner
Re: Scanner
I think there is a Mach3 plugin that does this, Have a look at this: http://www.brusselsprout.org/cnc/1p-probe/
