Used AutoLeveller for the first time yesterday, worked like a charm.  My mill has a vacuum clamp (vacuum cleaner source) that does a pretty good job of holding the board down flat, but, the results still weren't perfect.  Now with AutoLeveller, it's perfect, thanks for your great work.
I'm using Mach3. I use Coppercam to make my boards, they include in one file all the routines to make one side of the board.  The routines are ordered with the engrave first, then a mill function to remove large areas of copper with a 1mm end mill, then the drilling functions (usually 3 seperated drills), then the board outline cut function using a 2mm mill.  The program stops at each of these tool changes.  I typically move the mill to 0 X, 0 Y and 0 z to make sure that it is still in allignment (it sometimes is off on the x by .5mm or so).  Then I move the Z up high enough to change the tool.  The reset to Z to zero.  After the tool change I start the program routine and it heads off to complete the next milling opperation.
I had been using the estop feature to re-set the Z to zero when changing tools.  With AutoLeveller, the Z for the first tool is set by program, but, when I come to a tool change, it would be nice to be able to run a short AutoLeveller routine to set the Z to zero for the new tool.
						Re-setting Z to zero when changine tool
Re: Re-setting Z to zero when changine tool
Great to hear it worked well for you Ken
I have just (about an hour ago) released version 0.8.0 for Autoleveller members. Which covers the much requested 'probe-persistence' upgrade and will allow you to change tool and reset the Z from a single previous probe point.
I have tried to make it as easy as possible to use and have upgraded the guide http://www.autoleveller.co.uk/autoleveller-guide/
Have a look and let me know if you have any questions.
Well how cool is that!
I'll look right away. Thanks for all your efforts. Donation on the way.
Regards,
Ken
Regards,
Ken
