Respected colleagues,
I am new Autoleveler user and when I have tried to use Autoleveler application I have generated PFG file (attached) and measured deviation of my CNC table with this generated file in the Mach3 software (Version R3.043.062). When I try to import file generated from Mach3 software (atached), Autoleveler application show a RPF Load Error (screenshot attached).
Can somebody tell me what is the problem and can it be solved ?
Thanks in advance.
Best regards,
Dragan
What is wrong with generated RPF file
- Surface Map.txt
- Generated surface map from Mach3
- (28.16 KiB) Downloaded 2084 times
- RPF Load Error
- RPF Load.png (25.45 KiB) Viewed 12724 times
- PFG~286x333.nc
- Generated PFG file from Autoleveler
- (51.89 KiB) Downloaded 1817 times
