I use Vectric Aspire to generate a gcode file for LinuxCNC and Aspire starts and ends the file with a "%". Autoleveller inserts the probing routine before the "%" which then causes a bad character error in LinuxCNC because the start "%" is in the wrong place.
All seems to be ok if I manually delete the "%" or move it back to the start of the file.
regards
Paul
						Bad character "%"
Re: Bad character "%"
thanks Paul,
I have logged it, and will fix it in the next release.
