Absolutely,
Even the free version of AE has the option of changing the XY Feed.
The autoleveller no work in my machine CNC 3040 USB
Re: The autoleveller no work in my machine CNC 3040 USB
I have a problem with that version, I'm not (member download) and I to saw that didn't work the past version, I didn't pay the privilege, now if I could try the last version and I check that it works then if I become a member
daedelus wrote:Absolutely,
But the problem I don't have in the speed of the Z axis, it is in the speed of the axis Y and X, if you see the video you will see that it doesn't work in a stable way, even the free version of AE
Sorry for the late reply.
This is the free AutolevellerAE 0.7.0 (http://www.autoleveller.co.uk/download/): Forgive me if I dont understand, but is this what you need? You can change the XY feed to whatever you want.
Ok, now it doesn't accelerate and not it loses steps, but it still doesn't work, I have verified that I have to change the parameter "Prove Safe Height" and lower it so that it doesn't give me the error of limits, but it doesn't work fine.
When starting the work starts fine, but in the course of the road is sinking more and more the tool and destroys the pcb.
I don't know what I do bad
Lets list the facts here, just to be clear....
- By lowering the XYfeed, you no longer have issues with acceleration or missing steps
- Lowering the Probe safe height eliminates any software limit errors
- Probing seems to work OK
- During etching, the tool sinks lower and lower and ruins the PCB
- If you etch the file without running through Autoleveller / AE the job completes as expected, though without levelling obviously
Is this correct? Have I missed something?
It sounds increasing likely to me that your Z axis is incorrectly set in Mach 3. This is how Art saw the situation as well I believe.
First, I think you need to check the 'reversed' setting for the Zaxis in Mach3, like this:
You also need to check the settings in motor outputs. Depending on how you wired your CNC, you may need to check the 'Dir Low/Active' of Z axis as well. This will cause your Z axis to down on a negative command and up on a positive command as it should.
Yes, it seems to work finedaedelus wrote: - By lowering the XYfeed, you no longer have issues with acceleration or missing steps
Yes, it apparently that works like thisdaedelus wrote: - Lowering the Probe safe height eliminates any software limit errors
Yes, the probing work fine, i use this code:daedelus wrote: - Probing seems to work OK
'chengdu xhc tec. probe z surface macro
FeedCurrent = GetOemDRO(818) 'Get the current settings, OEM DROs (818)=Feedrate DRO
ZCurrent = GetOemDro(802) 'OEM DROs (802)=Z DRO
GageH = GetOEMDRO(1001) 'OEMDRO(1001)=Gage Block Height
ZNew = ZCurrent - 300 'probe down 20 mm
Code "G90F200" 'slow feed rate to 100 MM/MIN
SetOemDRO(818,200)
Rem Code "G4 P1" 'Pause 1 second to give time to position probe plate
Code "G31 Z" &ZNew
While IsMoving()
Sleep(10)
Wend
Call SetDro (2,GageH) 'DRO(2)=Z DRO
FinalMove = GageH + 10
Code "G0 Z" &FinalMove
Code "F" &FeedCurrent 'restore starting feed rate
SetOemDRO(818,FeedCurrent)
Yes, that's what happens, and other times the tool stays in 1mm of distance to the pcb and not lowdaedelus wrote: - During etching, the tool sinks lower and lower and ruins the PCB
Yes, exactlydaedelus wrote: - If you etch the file without running through Autoleveller / AE the job completes as expected, though without levelling obviously
it is correct. and no, I think nodaedelus wrote: Is this correct? Have I missed something?
This way I have configured my machine, and what I don't understand is that with Gcode without autleveller it works welldaedelus wrote: It sounds increasing likely to me that your Z axis is incorrectly set in Mach 3. This is how Art saw the situation as well I believe.
I have set the machine that zero is on the front left and the Z axis up.daedelus wrote: You also need to check the settings in motor outputs. Depending on how you wired your CNC, you may need to check the 'Dir Low/Active' of Z axis as well. This will cause your Z axis to down on a negative command and up on a positive command as it should.
I make the test of sending order negative Gcode (G0 Z-3) and the Z axis and it works fine.
I upload the image of how the engines are configured
I will check my own machine tomorrow but just to say...
In the 'Motor Home/Soft Limits' screen, try marking the 'Reversed' field for Z axis, see if that makes a difference.
The only difference is the probing bit (all the G31's etc.) so the problem is something to do with the probe. But, from your video, the Z axis seems to be going in the right direction fine. Maybe the probe stage is storing the wrong numbers on each point, causing the calculations to be wrong. Just a thought.This way I have configured my machine, and what I don't understand is that with Gcode without autleveller it works well
I have modified that parameter and it is shared equally.daedelus wrote: In the 'Motor Home/Soft Limits' screen, try marking the 'Reversed' field for Z axis, see if that makes a difference.
I don't know if you'll see it in the video but when the machine do the probing routine, sometimes all three axes move at the same time, I think that should not be so
Apologies for my lateness,
Here are the screengrabs I promised taken directly from my Mach3 setup: As you can see I dont have the 'reversed' field checked for Z either but 'soft max' is set to 20 for Z. If you do similar, you should not need to lower the 'probe safe height' in the autoleveller settings. (Probably a unprofessional way to do things, I am not a Mach3 expert though)
I cannot see much difference in our setups though.
I did not see that in the video. But given this, maybe the mach3 'motor tuning'? needs adjusting, these things:I don't know if you'll see it in the video but when the machine do the probing routine, sometimes all three axes move at the same time, I think that should not be so
