Hello guys,
I am new to the whole cnc thing not only the autolevelling software,
Trying to etch PCBs here .. downloded the free version .. set up the probs and got everything ready.
The it worked but with a lot of air cuts .. so i upgraded to the premium version and filled the custom controller parameters as the following ..
https://pasteboard.co/HP6fy0LS.jpg
https://pasteboard.co/HP6gAKs.jpg
And the mach3 screen won't even show the path when i load the levelled gcode .. and of course don't run ..
https://pasteboard.co/HP6ifRH.jpg
What am i doing wrong ?
I am using mach3 on windows7 .. my machine is using serial port for communication.
The generated code is attached.
Thanks in advance,
Generated file won't work !! Help
- ALCopperoldnnnnnnnnnn.nc
- (57.53 KiB) Downloaded 1252 times
Re: Generated file won't work !! Help
Hi Hamed,
Take a look at these lines from the GCode:
The lines with F300 have a lowercase f at the end. I dont know why you see this but I just used a text editor to remove these f's for now. There were 45 of them and were the reason Mach3 refused to load it I think.
I will look into this when I can, but have you got any ideas why in the meantime?
G01 F60 Z-0.02107
G01 F300 X11.29 Y6.781Z-0.02054f
Hi james,
Yes the "f" was the reason, don't know the cause and the original file didn't contain any.
It was created with coppercam.
Something else, i read nearly every topic in the forum and followed the instructions to fill the custom controller parameters.
However, after probing fine, the bit doesn't etch .. it floats with a certain offset above the surface .. it only itches like 20% of the time.
So basically it works fine one time each 5 trials.
Any idea what may be causing this ?
Thanks for your time,
And it's Khaled btw
And it's Khaled btw
Hi Khaled,
Apologies for getting your name wrong, I must have got muddled up with the other guy I was talking to on the forum at the same time. I tend to get muddled sometimes
Im guessing that the probe values are not being recorded properly sometimes. Check the RPF after probing. The first Z value should be close to 0. If not and if its a relatively large positive number then the tool will likely hang above the surface.
Have you tried selecting Mach3 as your controller and not Custom Controller? Does this work?
Hi james,
Yes i tried it and it won't work unfortunately.
I used to run (auto level ) directly without going to the RPF procedure.
Yet, i did so as per your instructions and the first z value is -0.10156.
however it still floated with an offset
Can it be something with the controller ?
Also forgot to mention that sometimes it gets stuck in one of the g31 lines, and i would have to restart the pc running the mach3 so that it runs again.
On further trials ..
now the first z co-ordinate is 0.2 .. IN POSITIVE and of course still floating
I dug out this old small RPF of mine so you have something to compare to.
It was made using LinuxCNC so it will look different to the Mach3 RPF's but the Z values should be similar.
You can see here that the first Z was "0.005680". There are a few random / noisy values here but they average around 0.08.
Let me sleep on this, things might be clearer in the morning.
-0.500000 -0.500000 0.005680 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
24.750000 -0.500000 0.165586 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
50.000000 -0.500000 0.215557 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
75.250000 -0.500000 0.173915 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
100.500000 -0.500000 0.024003 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
100.500000 26.500000 -0.437394 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
75.250000 26.500000 0.063979 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
50.000000 26.500000 0.682302 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
24.750000 26.500000 0.072308 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
-0.500000 26.500000 0.030665 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
-0.500000 53.500000 0.062313 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
24.750000 53.500000 0.067310 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
50.000000 53.500000 0.068976 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
75.250000 53.500000 0.065645 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
100.500000 53.500000 0.068976 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
100.500000 80.500000 0.112284 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
75.250000 80.500000 0.167252 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
50.000000 80.500000 0.170583 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
24.750000 80.500000 0.135604 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
-0.500000 80.500000 0.065645 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
Hello James,
Tried several different scenarios and concluded that the error is in the readings taken by my machine as you said.
I probed the same area 3 consecutive times with the same file and it produced different values like shown in this image
https://i.ibb.co/x1KNZtk/IMG20181204151739.jpg
can the USB interface cause this? the controller?
If that is normal, if you look at it well, there is a difference of 8 hundredths
