Leveller first try
Posted: Sun Oct 13, 2013 2:27 pm
So after getting the autoleveller windows version running ok I had the autoleveller run my gcode as generated
by pcb-gcode. It generated the new g-code with probing and z movement corrections ok as far as
I can see but the file is somewhat obscure to me since I have no idea how the corrections are implimented.
I set up my pcb mill and started the gcode with levelling, since I start at the right side being a bottom etch
the machine moves the spindle all the way to the left side of the pcb but within bounds of the pcb outline.
Then it sat there with no z axis movement, I hit cycle start again then it started moving the z axis and taking
measurements. The first time it went along most of the path then near the last 2 tracks it was like not getting the
probe contact so would drive down that 1/16 of an inch. So I stopped it rechecked the probe contact using mach3
diag screen and it showed it was working. Reset everything and tried again, this time it made it all the way, probed
70 points then stopped for a tool change which I didn't have to do since I was using the engraving bit as the
contact. I hit cycle start again to continue and the spindle went to the first spot and the z axis went down BUT
didn't stop where it should have and went thru the pcb and into the table. The tip of the bit broke off but it still
cut ok just made a wider path which was fine for the pcb I was doing and didn't need to take multiple runs.
Like I said at the beginning I looked at the gcode that autoleveller generated but can't tell why the z axis went
that deep. I did restart the pcb engraving with out leveller corrections and it ran ok other than the engraving width
was wider since the bit tip was damaged (a Soigeneris bit I might add, it took a licking but kept on ticking).
I would be willing to upload or send the autolevelled gcode file so someone that is familiar with its coding
can tell me why the z axis did what it did.
Thanks,
Bruce
Thanks,
Bruce
