Page 1 of 2
AutoLeveller updates
Posted: Mon Oct 14, 2013 2:22 pm
Just added an update for AutoLeveller 0.7.7.
If the input gcode file does not state the units (G20/G21) then a dialog box asks the user to manually select either inches or millimeters.
Please download the latest if needed: http://www.autoleveller.co.uk/download/ and let me know if there are any major problems with it :)
Re: AutoLeveller updates
Posted: Mon Oct 14, 2013 4:36 pm
Seems to be working here running a quick test on a previously run gcode file. :D
Posted: Mon Oct 14, 2013 4:50 pm
cheers Art. :)
Posted: Wed Oct 16, 2013 8:57 pm
by Hessel Oosten
And "YES OK HERE" too, at the level of the problematic G-code-producer ....:-).
Thanks James,
Hessel
Posted: Wed Jan 01, 2014 1:15 am
by dfajardo
Daedelus -
This is great software, just what I needed. Thanks!
Don't like to be the bearer of bad news, but there is a (hopefully small) problem with the website.
I was not able to download the current version of AutoLeveler from the website (from http://www.autoleveller.co.uk/, when I click on "Downloads" I get an "Archives" page with the message "It seems we can't find what your're looking for. Perhaps searching can help." and a search box. As a result, I am using version 0.7.4, which was the latest available from the website under "Previous Versions".
*** Doug F.
Posted: Wed Jan 01, 2014 1:36 am
Doug,
I also found the same problem as you stated.
However, I also typed in "down" without the quotes in the search box and scrolled down and it came up with links to the two types of 7.7 and clicking on that started a download.
Hope this helps as I am sure James is either partying hard (its after midnight over there) or in bed.
Good Luck
Posted: Wed Jan 01, 2014 6:39 am
by dfajardo
Thanks Country-Bubba; I found the 0.7.7 version just as you indicated. Happy New Year to both you and to Jim !
Posted: Thu Jan 02, 2014 11:42 am
I am still not sure what caused the problem but the downloads page should be fixed now. Let me know if not.
Posted: Thu Jan 02, 2014 1:44 pm
Looks good on this end.
Posted: Sat Jan 04, 2014 2:38 pm
by minitreintje
It's fixed! Thanks!
Dylan
