[ABANDONED] what is wrong with this RPF data file?
Posted: Mon Feb 24, 2020 6:18 pm
Hoping to get an answer for this AL-related problem here the issue:
After making all Y-values within an X-row equal to persude AutolevellerAE-0.9.5u2 to load it AL shows for no comprehensible reason on some points gigantic values out of the displayable range (spindle.top.etchm3mm_RPF2.txt):
Using a RPF-file measured with the same settings a few minutes later the display after loading this file is normal as expected;
So I hope, that someone can tell me, what is wrong with "spindle.top.etchm3mm_RPF2.txt" that it produces such a maniac surface. I can't see the reason for this strange behaviour by myself.
