Compiling Help.
Posted: Sun Jun 22, 2014 11:56 am
by Ironaxe
Hey there. First i wanted to thank you for making such a nice Piece of Software :)
But now ive got a little Problem. I love to learn new stuff and so i tried to compile the Source myself and ran into an Error.
Im using Netbeans to Compile/Debug the Project on Windows 7 x64.
Im able to Debug the Project without any Problems. ( Everything works as expected. )
But when i try to Debug the Test Files or try to Build the Project i get 2 Errors.
I hope you can help :)
fullWrite
 Expected: is <x = -6.5408y = 49.4062z = -0.14413> but: was <x = -6.5408y = 49.4062z = -0,14413>
java.lang.AssertionError
	at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:20)
	at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:8)
	at com.cncsoftwaretools.autoleveller.ProbeTest.fullWrite(ProbeTest.java:148)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:44)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
	at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
	at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:271)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
	at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:53)
	at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:123)
	at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:104)
	at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray(ReflectionUtils.java:164)
	at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke(ProviderFactory.java:110)
	at org.apache.maven.surefire.booter.SurefireStarter.invokeProvider(SurefireStarter.java:175)
	at org.apache.maven.surefire.booter.SurefireStarter.runSuitesInProcessWhenForked(SurefireStarter.java:107)
	at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:68)
interpolateX_realValues
 Expected: is <x = -20.766y = 52.4488z = -0.01624> but: was <x = -20.766y = 52.4488z = -0,01624>
	at com.cncsoftwaretools.autoleveller.ProbeTest.interpolateX_realValues(ProbeTest.java:134)
Re: Compiling Help.
Posted: Sun Jun 22, 2014 1:46 pm
Hi Ironaxe,
You might see that your Z is being read as "z = -0,14413" rather than the expected "z = -0.14413" i.e. a comma not a dot, when my unit tests run. This is because the decimal separator is dot in the UK and other countries. In other counties a comma is used as a decimal separator and hence I can run the tests and build OK whereas you see errors.
I might be wrong but you are probably from another European country? so Java has set your Locale for this country and hence it replaces dots with commas in some places. What you need to do is skip the tests when you build the source code and you should be able to build it fine.
I dont use Netbeans myself but this might help...
http://stackoverflow.com/questions/6074 ... s-when-bui
I will fix this when I can, but for now you should be able to just skip the tests as described in the link.
Hope this helps.
Re: Compiling Help.
Posted: Sun Jun 22, 2014 4:57 pm
by Ironaxe
Ah. ^^
OK. I will try that.
Just wondered why it failed when the values are the same. ( Did not notice the , instead of the . )
And yes. Im from Germany :D
THX allot.
Re: Compiling Help.
Posted: Sat Jun 19, 2021 9:09 am
by SelmaAdam
The decimal and dot separator errors.Sometimes it's quite annoying
Re: Compiling Help.
Posted: Tue Jun 11, 2024 8:13 pm
by FrannyStephLux
How did that go? I keep encountering such every time in my navigation.
Re: Compiling Help.
Posted: Tue Jun 18, 2024 10:41 am
by FrannyStephLux
daedelus wrote: Sun Jun 22, 2014 1:46 pm Hi Ironaxe,
Hope this helps.
I can see this issue with decimal separators causing frustration in your testing process. Have you found any effective solutions or workarounds to manage this problem while ensuring your builds run smoothly?
