Could not load RPF file.
userhomeinit
Post by userhomeinit »
I managed to solve the issue due to the CNC USB problem, I have a clean file with the correct probes but still could not load it.
When I click file>raw Prob file, it shows me an error that the format is not the same.
In the generated file I have data like this:
5.58281,5.23185,-0.00125
42.89120,5.23185,0.08517
80.19959,5.23185,0.19163
117.50798,5.23185,0.14404
154.81637,5.23185,0.02568
154.81699,38.34326,0.02568
117.50860,38.34388,0.11022
80.20021,38.34326,0.15969
42.89120,38.34388,0.10897
5.58281,38.34388,0.01378
5.58343,71.45467,0.05073
42.89120,71.45591,0.11648
80.20021,71.45529,0.13777
117.50860,71.45529,0.07014
154.81699,71.45529,-0.02192
154.81699,104.56670,-0.16345
117.50860,104.56670,0.01691
80.20021,104.56732,0.11648
42.89182,104.56670,0.09832
5.58343,104.56670,0.01879
the first probe Gcode file is this:
M40
G0 Z5
G1 X5.5826 Y5.2324 F1000
G4P1
G31  Z-1 F80
G0 Z5
G1 X42.8913 Y5.2324 F1000
G4P1
G31  Z-1 F80
G0 Z5
G1 X80.2 Y5.2324 F1000
G4P1
G31  Z-1 F80
G0 Z5
G1 X117.5087 Y5.2324 F1000
G4P1
You could find the whole file in the attachments, the gcode file coordinates are in 4(10.xxxx) digits and the measured vales are in 5(10.xxxxx) digits could this cause a problem for Autoleveller?
PFG_149_99_3.nc
(3.03 KiB) Downloaded 1222 times
log_file_25k_10.txt
(564 Bytes) Downloaded 1195 times
userhomeinit
Re: Could not load RPF file.
I figured out that we have to correct the code and format it using Autoleveller;
the code generated by the CNC is not what the tool expects...
I did this and generated the code for my PCB and boom it works :D :D :D :D
Thank you!
