What is wrong with generated RPF file
MisterQ
Post by MisterQ »
Respected colleagues,
I am new Autoleveler user and when I have tried to use Autoleveler application I have generated PFG file (attached) and measured deviation of my CNC table with this generated file in the Mach3 software (Version R3.043.062). When I try to import file generated from Mach3 software (atached), Autoleveler application show a RPF Load Error (screenshot attached).
Can somebody tell me what is the problem and can it be solved ?
Thanks in advance.
Best regards,
Dragan
Surface Map.txt
Generated surface map from Mach3
(28.16 KiB) Downloaded 2049 times
RPF Load Error
RPF Load Error
RPF Load.png (25.45 KiB) Viewed 12661 times
PFG~286x333.nc
Generated PFG file from Autoleveler
(51.89 KiB) Downloaded 1782 times
