G31 Loop
rgon
G31 Loop
Post by rgon »
I always get stuck in this loop and cant figure out what i am missing. Can some one help?
https://www.youtube.com/watch?v=t5MgTdLZDjA
Same problem in AL0.7.7, ALAE0.7.0 and ALAE0.7.6
ALPFG253.0x241.nc
(10.12 KiB) Downloaded 1808 times
Thks,
Rui
rgon
Re: G31 Loop
Post by rgon »
Forgot to say that the controller is an YooCNC USB.
Re: G31 Loop
Very odd.
The line "G92 Z0" should set Z to 0 for every offset, yet in the video Z seems to be reset to 0.125 after this line then it jumps back 2 lines to the "G0 Z2" line. Does G92 have a special meaning through YooCNC or something?
Try entering the MDI command "G92 Z0" manually to see what happens.
rgon
Re: G31 Loop
Post by rgon »
G92 Z0 works fine in MDI.
Also did the sequence in MDI and all commands work successfully
G0 Z25
G1 X0 Y0 F1000
G31 Z-1 F5
Mach3 error log after run autoleveller gcode.
LastErrors.txt
(743 Bytes) Downloaded 1625 times
Re: G31 Loop
Aha I think ive seen the error.
Mach3 doesnt like comma decimal separators so when it hits the line "G31 Z-1 F2,5" thats where the error occurs. It should be a point not a comma for the feed rate, i.e. "G31 Z-1 F2.5"
Did the gcode file come from AE0.7.6 because I thought I had fixed this issue before then?
For a quick workaround you can do a "find and replace" in a text editor to switch the commas into points. I will check and fix as necessary though.
