error in mach3...
allnew
error in mach3...
Post by allnew »
When I load the autolever gcode into mach 3, I receive the following error:
"radius to end of arc differs from radius to StartLine939"
which then prevents me from running and testing the code.
Any ideas?
thanks
tony
Zig
Re: error in mach3...
Post by Zig »
post a sample of Your G code with arc format.
allnew
Post by allnew »
code sample with error is in the attachment.
tony
ALgcode testCopperCAM.zip
(93.25 KiB) Downloaded 1518 times
Zig
Post by Zig »
Had a look at Your file on LinuxCNC software.
Reported unkmown G code at line 22 or thereabouts.
Did not have enough time to look at the report thoroughly.
Will try to locate offending statement
Zig
Post by Zig »
a little while later...
Changed G31 ( or was it G32 ) to EMC compatible statement G38.2 see the link for explanation of G38.2
commented T lines as current tooltable reported not to conatin tool
Program bombs out on an arc statement.
G2 I-0.019 J0 X1.9475 Y-0.959 Z[#100 + -1]
G0 F2999 Z2
G0 F2999 X1.9285 Y-1.059
G0 F1499 Z0
#102=[#580+0.23597*#602-0.23597*#580]
#101=[#581+0.23597*#603-0.23597*#581]
#100=[#102+0.59285*#101-0.59285*#102]
G1 F59 Z[#100 + -1]
#100=[#102+0.64203*#101-0.64203*#102]
G1 F300 X1.9475 Z[#100 + -1]
G2 I-0.019 J0 X1.9475 Y-159 Z[#100 + -1] ######## program bombs out on this line ( first instance of error)
G0 F2999 Z2
G0 F2999 X1.9285 Y-1.159
G0 F1499 Z0
Note Y value is -159 subsequent Y value 1.159 -previous Y value -0.959
Please check source of Y=-159
LinuxCNC reports
Near line 948 of...
Radius to end of arc differs from radius to start:
start = (X1.9475, Y-1.0590)
center = (X1.9285, Y-1.0590)
end = (X1.9475, Y-159.0000) r1=0.0190
r2 = 157.9410 abs_err = 177.9
rel_err = 99.9880%
This is probably not all there is in the file and You may need to go onion skin by onion skin ( with some tears )
I hope this helps.
Also just happen to think, as this is an arc problem,
is your mach set up for incremental or absolute in the ijk functions??? Most cam programs that I am aware of use incremental for their setup.
Just a thought.
Zig
Post by Zig »
... how did it go?
