Hi , I apologize for my poor english first. Here's my situation.
I'm using autoleveller on Mach3 (Chinese USB board, nMotion) and running into a G31 problem.
G31 command works well on other tasks when I need to set WCS on milling.
However, when I used the GCode generated by autoleveller 0.77, G31 SOMETIMES works while sometimes just staying there, doing nothing and going straight to next line.
GCode and Working situation as below
G31 Z-1 F50.................SOMETIMES Worked
#500=#2002...........Worked
G0 Z2............................Worked
G0 X5.21389 Y0........Worked
G31 Z-1 F50................SOMETIMES Worked
#501=#2002............Worked
G0 X10.42779 Y0.....Worked
#502=#2002..........Worked
G0 X15.64168 Y0......Worked
#503=#2002............Worked
The ratio (G31 Worked)/(All G31) is about 0.66, seemingly no obvious pattern there, just random.
Also, in "step by step" mode(ALT + N), all the G31 work CORRECTLY all the time.
Does anyone get some clue?
thanks!
G31 Probe SOMETIMES works (Mach3 USB) (SOLVED)
Re: G31 Probe SOMETIMES works (Mach3 USB)
Very odd,
I suspect it has something to do with your USB board though.
Is there some difference between the G31 lines on the tasks that work and the Autoleveller G31 lines?G31 command works well on other tasks when I need to set WCS on milling.
It all looks the same hahadaedelus wrote: Sun Apr 22, 2018 9:22 am Is there some difference between the G31 lines on the tasks that work and the Autoleveller G31 lines?
thanks daedelus,
I would like to know if autoleveller get no probe information in staging, will it still work?
I've tried another controller with parallel port just now, and it worked well.daedelus wrote: Sun Apr 22, 2018 9:22 am I suspect it has something to do with your USB board though.
Are there possibilities of my hardware(RAM or CPU)'s problem which may cause Mach3 working like this?
Re: G31 Probe SOMETIMES works (Mach3 USB) SOLVED
Finally get this solved by update my mach 3 version (3.041 to 3.043)!
thanks for helping daedelus!
Re: G31 Probe SOMETIMES works (Mach3 USB) (SOLVED)
Just for the record, in the member version its possible to enter your own values for probing in the RPF and use this file for Autolevelling instead of probing and writing to a bunch of parameters as is the case in 0.7.7 (although this is not a good idea).
However, you have fixed it now, so this is a moot point. Nice one
