Re: Aircuts on Mach3 USB NcUsbPod
Posted: Tue Oct 23, 2018 2:22 am
I made a teste here. To work properly the command G4 P1, need come before the G31 Z-1 F100.
In the example Gcode it is coming after and does not works.
Another test was about the pause time.
The machine does not wait for one second to go down. Since the machine recognize the pause it starts to go down. I tested with 10 seconds and was the same. I believe that In a USB board the signals are multiplexed because we have only two pins.
The custon controller option, need to be an option to fill the pause command before the probe command.
Thanks.
Renato.
Thanks.
Renato.
